Do you think they can?????
get a buddy
and a tape measure
find a spot on the tire like a certain groove that is same all the way around the tire
then measure across the front of the tire
then do the same on the back of the tire
write down your measurements and on the tie rod sleeves you can adjust them in or out
make it to where the measurement on the front of the tire is 1/16" to 1/8" less in the front of the tire then it is on the back of the tire
that should put your alignment real close and then when u get it aligned they can make any caster or camber adjustments
these are your front tires measure from 1 to 2 and make that measurement 1/16" to 1/8" less than measurement 3 to 4
[IMG][/IMG]
and a tape measure
[IMG][/IMG]
