cruise after ABS/TCS delete
not sure if this is the right section, but I was wondering if anyone knew for sure if my cruise control will still work in my particular scenario.
just installed a moser 9"....no provisions for TCS/ABS.
ABS cable from body to rear end is removed (ABS INOP light on...expected that)
car was factory equipped with cruise, TCS, and ABS.
just wondering if the cruise control reads off of the vehicle speed sensor in the transmission, or if it used wheel speed sensors as well.
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Just uses VSS as far as I can tell.
I swapped out the TCS-version cables for a non-TCS
car, pedal-TB and Cruise-TB ran me about $75 if I recall.
Just to keep the TCS from meddling with the pedal.
