Subframe connectors, worth it?
#62
Who do you talk to?
#64
I completely agree, they transformed my car... the ride is better, it is quieter, handles better, feels more solid all around, I highly recommend them. I wish I would have gone with the 3 point SFC's though. My 120,000 mile/T-TOp car has never been better!
#65
So if my car's tail end kind of snakes at high speeds when turning or changing lanes, will SFC's help eliminate that? Or could that be worn out bushings?
I'm really considering SFC's, but at 50 lbs, and so many negative reviews, albeit a lot of positive ones, I really feel iffy about this...
#66
That's going to be more suspension related, not chassis stiffness.
But please, don't bump multiple old threads on the same basic topic. Keep all your questions in one as that is both more beneficial to you to have all the answers in one spot and far less annoying to everyone
#67
#69
Honestly I'm not sure if I need new springs, new bushings for the control arms, maybe 17 inch wheels, but this problem hasn't always been here, it's gotten worse with age and miles. I'm guessing bushings and springs should alleviate the problem, your take?
#70
Springs should be fine (at least not worn out, they really don't wear out too fast), shocks should be fine. I'd look at control arm bushings, sway bar end links, and also what brand of tire and how many miles are on them, are they wearing properly, etc... You could have the best suspension but if the tires are junk then it won't matter.
#71
I picked up a set of UMI 3 points about a year ago and Ive noticed a big difference. The car feels much more stable going into turns and just more solid in general. I am still on the stock shocks/springs with 120k miles. My car is a convertible though so it probably made a much larger difference then in coupes or hard tops.
