C6 rotors
Base C6 rotors are 12.8". Stock LS1 F-body rotors are 11.8". Therefore, the rotor will not fit under the caliper.
In order to correct this, you can order adapter brackets from various sponsors which allow you to use C6 rotors, and even C6 calipers if you like.
Front are 13" and rears are 12"
I can confirm this but, will they bolt-on?
HHHMMM just bought a pair of rear cross-drill rotors for my WS6 and the rears are exactly the same size as my C6 Rears...
I know that C6 had gone though some changes I know for sure the base (calipers/rotors) had change on the BASE C6 LS3 model.
Well, if they dont bolt-on then make them fit...simple.
The difference is in the rotors...perhaps that it what you meant
In order to run the Z51 setup, you will need Z51 rotors, C5/C6 knuckle adaptor brackets, C5/C6 calipers, and Z51 caliper brackets. And of course 18" or larger wheels.
