New BMR spring owners, I've got a couple of questions...
Guys, I had the NEW bilsteins on the car for 3 days. It drove a whole lot nicer but it still bounced the off the stops just driving around. I am selling the car and all the stuff that was on it so I didn't really put them through the test. All I can say is that I had a pro kit on my z28 with a set of bilsteins for over 3 years and never hit the stops once...
LS1TECH Sponsor
Use good (read not junk, but also appropriately valved) shocks and there isn't a problem. You are fooling yourselves if you think you can keep these cars off the bumpstops. They hit the stops bone stock guys.
It's simple. The combination of spring rate, height, quality, teamed with shock valving is used to control how hard/fast/often you hit the stops. A well damped contact is a whole lot different than slamming into them.....
__________________
LS1TECH Sponsor
I don't doubt the ride was better, but it wasn't because you weren't contacting the bumpstops before. That's all I'm sayin'.
__________________
Strano install (BMR)
EDIT: To clarify my previous post, my strano's were the same way as the BMR's in terms of installation. I could set the shock mount on top of the assembly and tighten down to spec without the need of compressing the spring (I did anyways, though). As far as your situation with bottoming out and overall terrible ride quality- I had the same problem on my first set of strano springs but my second set was waaaaay different than the first set. IDK? Somehow the first set I got must have got fucked up during manufacturing???? I think this put a bit of grievance between sam's view of me as a customer, but obviously I am happy with his service and prices since I chose to get ANOTHER set of strano's. Good luck with the setup!
My setup (NOT BMR/Strano) hits the bump stops all the time but it is tolerable because of the stiffness of the shock absorbers making it not as harsh as with a softer shock like a Bilstein HD. I was hitting the bump stops occasionally when stock, and I hit it more when lowered, and a LOT when lowered and on regular Bilstein HDs, but there's no way around that problem aside from making the shocks stiffer to avoid the suspension from compressing too fast. When you run a shock that is valved properly (read: stiff) for high-rate lowering springs, it stiffens the ride up and prevents the car from hitting the bump stops noticeably hard. Regular Bilstein HDs are not valved for lowering springs and do not have the proper internal bump stops for lowering springs. I went from 40k mile Bilstein HDs in the rear with Hyperco springs, to KYB AGX @ 7 with the same Hyperco springs, and there was a world of difference in terms of ride quality and not smacking the bump stops.
There's your problem right there. You want the Ferrari, but only want to pay for a Geo Prizm. If I wanted cheap performance on that sort of budget, I would have bought a Honda Civic instead of a V6 F-body. My $0.02.
