Can't Get My Shocks/Springs Off
I jacked the car up, took the wheels off, took off the two 50 hex bolts, and the other two bolts.
Then I took off the two bolts holding the shock at the bottom.
The shock moves left to right at the bottom where I removed the two bolts, but it does not move at all at the top where I removed the 2 hex/2 normal bolts
What Am I Doing Wrong?
I followed the walk-through on LS1 HowTo.com
http://www.ls1howto.com/index.php?article=6
They say by the 6th step, that the assembly should be loose under the car. Mine was still stiff as if I didn't even loosen the bolts.
Altogether, I should have taken off 4 bolts on the top, and the 2 bolts on the bottom right?
did you remove the castle nut from the upper ball joint? and then disconect the swaybar endlink so the lower a arm can swing down a bit further. it should come right out. hit it with a rubber mallet.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
It came free and I put some foam padding under the rotor to hold it up to un-stress the brake line.
The spring/shock assembly didn't even budge from the top after I removed the bolts and the Ball Joint.
Any other idea what it could be?
Perhaps I just have to man up and give it a thwack with a rubber mallet?
Yep sometimes they just get rusted in there you wont hurt it just give it a good wack and it should pop out. Removing the sway bar end links help too it the one bolt coming down from the sway bar on each side.
The shock assembly is at the machine shop now and their trying to get the rusted shock nut off. I wasn't even going to put myself through that headache.
