Car Wobbles
Old Apr 16, 2010 | 12:35 AM
caseypryan's Avatar
Originally Posted by SparkyJJO
Did you check your sway bar end links? Worn bushings there can allow the car's body to have more roll. Also check the bar itself - mine had cracked on one side so between worn end links and a cracked bar my front end was a little jiggle happy.
+1 those end links break really easy
Old Apr 17, 2010 | 12:37 AM
Detoxx03's Avatar
Ever thought about a damaged shock? Mine does this but mainly on the front passenger side. I'm checking my tie rods on sunday but was told that it most likely is my shock.
Old Apr 18, 2010 | 02:28 AM
alsfastz28's Avatar
Try checking front hub bearing or rear sway bar end links.
Old Apr 19, 2010 | 01:52 AM
pemberton's Avatar
End links look fine, tires are at 32psi, tie rods are fine, all bushings look normal. I am beginning to think it's maybe the rear shocks. They are the ones that came on it. The front ones were replaced with KYB a year ago, and the springs are that old. So that's the only thing I can think it might be. Any more suggestions?
Old Apr 19, 2010 | 01:59 AM
pemberton's Avatar
Originally Posted by rabbit320
i would recommend the panhard bar, being off that much makes a difference, to me / my car at least. im lowered with simple bolt ons. as to that being the root problem... got me. but i have same problems of weaving and i know mine needs to be re-adjusted. mine also binds bad on some corners.
Rabbit yours sounds exactly like my problems. How far off was your rear end after lowering and before the pan hard bar? Did you do anything else to eliminate the weaving? Mine seems to catch in grooves in the road really bad now. I just assumed it was because my front tires are 10" wide.also you said yours binds bad in corners and I'm not quite sure what that means...
