are KBDDs necessary?
Old Jan 14, 2004 | 04:14 PM
Stone0fFire's Avatar
Default are KBDDs necessary?
kenny brown double diamond subframe connectors are
expensive
heavy
but look very sturdy and look like theyd help more then "regular" SFCs,
like BMR.
but is there really a difference?
and will they get in the way of long tubes? deep trans pan? aftermarket y pipe?
anyone own more then one set of SFCs on one car or drive a couple fbods and notice a diff?
Old Jan 14, 2004 | 08:12 PM
Gev's Avatar
Gev
KBDD stiffens it up for turns as well as straights. The standard ones do nothing for stiffness through turns.
I have them and they don't get in the way of anything.
I have however heard that the SLPs are much stiffer than the KBDDs, but they weigh a little more.
Old Jan 15, 2004 | 11:36 AM
Fast Eddie's 02 T/A vert.'s Avatar
I'm very happy with my KBDD SFCs.It made one hell of a difference.When my car is put up on the rack,the doors open and close just fine and mine is a convertible.
You loose a little clearance under the car though,i scrape a little more going over high speed bumps.
Old Jan 21, 2004 | 05:30 PM
wtf?
SLP? no way!!
anyone else know anything about this?
btw..
its an auto,
so dont need super-stiff turns
which ones should i get for straightaway only?
Old Jan 21, 2004 | 05:44 PM
jmorgan's Avatar
I have KBDD and Love them they are a little heavy tho. If your just going strait then i would look at some regular BMR subframes
Old Jan 21, 2004 | 06:10 PM
glitch77's Avatar
SLPs over KB anyday...
Old Jan 24, 2004 | 05:21 PM
alright the 245/50/16 dr's are not enough
im gonna go with fat et balloons,
so the cornering is gonna get crappy anyway
gonna get "regular" ones like BMR
but..
i dont like BMR
i want something that wont break.
any suggestions?
Old Jan 24, 2004 | 07:09 PM
WILWAXU's Avatar
LMAO!
The SLP's are heavier than the KBDD. They have nearly all the same attachment points. If you welded them in, they're probably close to if not the same as KBDD.
With that said.
The KBDD provide great structural rigidity. They are a little over kill. They do add extra weight, but provide a little extra support.
Even after 100's of passes my car is still tight as a drum.
