ES Poly trans mount
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Finally bit the bullet and thought I would try a poly trans mount after breaking 3 stock replacements. I did sand off the preload bumps and didn't use the extra preload bracket.
The difference was great! No added annoying vibrations and the feel of the transmission is noticeably more firm when shifting both up and down. Should have done this sooner. Anyone not sure about the poly mount, get the ES piece and grind/sand off the preload bumps.
Next thing is poly motor mounts, my y pipe is hitting the bottom of the car. Looking forward to finally get his thing tightened up. As soon as I added the extra power it has found the weak points in mysetup. First was the lower control arms, torque arm bushing, torque arm, trans mounts and now the motor mounts.
