setting up anti roll bar
Ok guys I read a thread awhile back and have searched for it with no luck. It said sumthin about adding your weight to the driver side and setup from there. What i want to know is how to set it up the easiest and best way? Thanks guys!
Hello
Like you mentioned. You will have to either be in the vehicle yourself or have a friend that is close to your weight. To allow you to set the preload of the vehicle so when you launch the vehicle at the track it will leave straight. If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
Like Jim mentioned above. That is the baseline set up. And you will have to fine tune the suspension at the track to see how the vehicle will react during a shack down pass. All setups are different but I am sure once you get that setting you will not be disappointed. If you have any other questions feel free to ask.
Thanks
Brad
