QA1 Shocks R Series
If you are interested in handling (and have a little more money to spend, buts its well worth it) look into some Koni SAs (http://www.stranoparts.com/partdetai...D=20&ModelID=7).
You wont believe you are driving the same car, huge change in grip, ride quality, balance, stability and control (think BMW 3 or 5 series).
I have these and personally wouldn't own another fbody with at least these (or a higher end shock).
Search this section and you will see tons of threads with good info. (search "handling" and while you are at it search "strano").
thank you JD_AMG for the Info
the reason im asking is i found a set of shocks for about 550$
but i think i will wait and get the Koni
right now i have a set of eibach and blisten but the front is bouncing badly
thank youu
thank youu
Buying new also gets you a warranty (and in the case of konis you get a lifetime warranty, and if you buy from Stranoparts, Sam will walk you through the install and setup and help with any issues.)
