Stb
FWIW...I installed both a 3 point STB, as well as 3 point SFCs in my car. I daily drive the car, so if there was any immediate difference, I didn't notice it. However, a friend of mine rode in the car before these modifications, then again, a couple of weeks later. He said he felt a difference...
This is a 5th gen Camaro, and it uses a MacPherson strut which focuses all the load on the top of the tower (or near there). The 4th gen fbody uses a double A arm/spindle type setup, and most of the load of the suspensions is transferred through the lower A-arm into the K-member, NOT the top of the shock tower. This is one of the reasons that some cars like STB's, and some cars dont need them at all.
Also, I might add, I question the validity of videos like that. Without actually measuring strain in the STB, just seeing a video of an end bounce around doesn't tell me that the car is actually flexing. Try putting a STB into your car, and only bolting down one side. Now, give your STB a slight slap on the other side of the car....I bet you it moves! What do you think happens when you're driving down the road, hitting bumps, etc.? That's one of the things that happens when you have a piece of tubular steel about 3 ft long bolted down in 2 places (even 4 in the video).
Anyone interested in getting some numbers?
All it takes for an aftermarket item to exist, is demand. In fact, the aftermarket has even come out with products, with no demand, and created demand with hype.
Even the OEMs equip their cars with items or specs, where the deciding factor could only have been marketing, and appealing to people's "common sense" understanding of what a sports car needs to perform.
I'm not claiming that I have done a before and after on a 4 post shaker, to actually have the data, but I am going to do some things to increase the torsional rigidity of my FD RX-7 (LSx swap), also with double A-arms all around; the first things I am doing are stitch welding the unibody, and "foaming" the unibody equivalent of the "frame rails". Torsional rigidity is very important to me, and you won't find an aftermarket strut bar on my car (there is one in the rear stock. I don't have the front stock STB, and they don't fit with an LSx. If I did have the stock front STB, and it did fit, I would probably just use it anyway.)
I
Cars are going to flex some when you drive them hard, whether it's at the drag strip or on a road course. Too many people are getting caught up in this, "I gotta stop ALL chassis flex!" idea when it's impossible, and impractical were it even achievable.
I have to think it's possible that, even if the major load paths don't go through the shock towers, that at some point, with enough mechanical grip, the forces going through the other load paths become so great, that they get transferred through the whole car.
Any structure has a natural harmonic frequency at which it resonates. The more rigid it is, the higher this frequency. If I didn't know otherwise, intuitively, I would say the same thing as what you did. It is very counter-intuitive, until you do a little research; at which point it does become intuitive (your intuition is informed by your knowledge and experience, you know?).
A more rigid frame will transmit more NVH not absorbed by the suspension (and in this context, we're not talking a town-car cruiser suspension; we're talking stiffer rates, higher-durometer bushings or rod ends, etc, meaning we can count on even less NVH dampening from the suspension on a performance car). Yes, it will also make handling better and more consistent, but you also have to keep in mind the fact that most people aren't going to auto-cross or road race, ever, and balance diminishing-returns modifications and NVH increase over the benefits seen in a daily driver.
While I'm sure most people would enjoy having a vehicle that handles as precisely as an F1 car, I doubt they'd be too happy with the comfort trade-off required.
Just to clarify, I'm not debating that a more rigid frame would in any way detract from the overall handling characteristics of a vehicle, it's simply my opinion that some chassis flex is permissible in non-race oriented vehicles, to maintain a broadly-appealing comfort level while driving, assuming a realistic expectation of what the majority of OEM-supplied suspension parts will achieve on the road during their lifetime.
I'm sure that the horizontal (side loading) forces do indeed go through the lower a-arm. However, the top of the coil/shock/ upper a-arm has to be located by something, it can't stand out in mid air. That "something" is the upper portion of the shock tower, which restrains the up and down motion of the spring/a-arm. The STB ties both shock/a-arms to each other, to resist this up and down loading.
Again, I'd be very interested to hear about some of the idiosyncrasies you've encountered, or anything like that, that you found interesting.
