panhard bar.....good idea?
I have my car lowered with the pro-kit and was looking at the panhard bars at LMPERFORMANCE.COM for 90$.....should i grab it? or use the money for somthing else suspension related?
thanks
thanks
Adjustible allows you to reposition the rear end under your car. Do you notice one wheel/fender clearance to be smaller than the other? (If you have stock tires, you can get away with non-adj. but if you go with wider tires you'll probably need the adjustibility to avoid rubbing on one side)
