ls1 springs and shocks on a lt1?
A friend of mine is getting rid of his eibach sportlines and kyb shocks from his 2000 Camaro. Im thinking about getting them but will they fit on a 1994 Trans AM. Ive heard some places they will and some they wont.
thanks Chris
thanks Chris
LS1TECH Sponsor
Not a great setup... but they'll fit just fine. They are the same car chassis wise.
__________________
ok thats what i figured because eibach says they wont work. He said he'll give them to me for half, hes only had them on the car for a year. Do you think i would be better off waiting and getting something better. Ive already been looking at your combination deals
LS1TECH Sponsor
I'm probably a little biased... but considering I sell Eibach and KYB--but never recommend anyone use Sportlines and rarely recommend a KYB (different versions of those and it will always be a budget thing if I do recommend them) I certainly feel you can do much, much better.
__________________
ok thanks alot im gonna save up for a while and when im ready i'll definately come to you for my suspension stuff. but koni shocks and strano spring is my best bet right
LS1TECH Sponsor
I believe so, yes... But aside from that, there are many better options than what you asked about originally and a full Koni/strano setup. You could stock springs and Bilstein's, stock and Koni's, my springs and Bilstein's, just as a few examples. I don't know enough about what you are looking to "get done" and want from the car to make a recommendation here, right now, by forum post, e-mail, or PM.
As always if you want to discuss options, I'm here and you can call me.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
LS1TECH Sponsor
I realize that's not your goal (and that's no problem) but my springs are, I think some of the best launching lowering springs because I do two things. 1. I don't slam the car. 2. I run a softer rate than many which helps with getting power down. I did not do those things because of drag racing, I did it to get power down and make the rear end work as best I could over bumps. Both of which effect handling. Just a happy help to the drag racers we don't slam the car and kill the instant center position or run the car brick stiff.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
__________________
Ok so yours are basically an overall spring, I really appreciate all your help. I'm thinking after the winter I'll probably go with bilsteins and strano springs. Thanks for saving me from stiff eibachs
