Wheel Hub Options
(I work at Advance part-time, and I recently looked at the the National hubs, as I think I also have one going bad. They are Korean made, I wouldn't go there if it was my car...)
In the end, if you pick a known name, you should be fine. Bearings aren't rocket science. They are just ball bearings in a race. Really, the only variable that can distinguish manufacturers is the type of metal used in the bearings.
"Awww, come on guys, it's so simple maybe you need a refresher course. Heyya! It's all ball bearings nowadays. Now you prepare that Fetzer valve with some 3-in-1 oil and some gauze pads, and I'm gonna need 'bout ten quarts of anti-freeze, preferably Prestone. No, no make that Quaker State."
I don't know what to do for my car at this point. I was getting an intermittant "ABS INOP" light on the dash. Had a friend hook up a scanner, and we got a reading that the LF speed sensor wasn't functioning propely.
I didn't want to just throw money at the car, hoping to fix it, so I first pulled both front wheels and checked the bearings...they're tight, (OE 75,000 miles) and I unplugged both sensors, hit both sides of the connectors with WD40, blew out the connectors with compressed air, and drove the car for several days without incident. The cold breezes have hit my area, and snow is predicted to hit the area within the next few days, so I took the car for one last ride yesterday....
Thank you leadfoot4 for bringing this option to my attention.
