No brake pressure with stainless steal lines!
Installed a set of stainless steal lines on my 99 SS I did bleed all the lines and before starting the car had a firm brake pedal. Once I started the car the pedal went down to the floor and barely had any pressure. Is my booster or master cylinder bad?
And don't forget to go in order of the farthest to closest to the Master Cylinder. It should be Pass Rear, Driver Rear, Pass Front, Driver front. In that order and do it at least twice all the way around to get all the air out.
Good luck.
