dont like my stance need help!
so right know my car has stock everything except for blistein shocks/eibach prokit. im getting a 9 inch this winter with lcas, tq arm and drag bar. the rear of my car sits at a good height but i dont like how my front sits. is there anything to lower just the front to give it more of a staggered stance? really hoping on a reply tn so i can save 15% from umi!!
my rear sits pretty low to begin with just dont want it to low after i do the rear and some of the rear suspension. the front i want it just a tad lower then the rear so its staggered and has an aggresive stance. the main problem is there is to much of a gap between the wheel and wheel well. anybody have any more suggestions that can take care of this on a budget? and pics of your setups?
LS1TECH Sponsor
Your rear will come up with the 9" installed as the springs will be sitting on larger diameter axle tubes than with the GM rear. FWIW.
__________________
You might be able to just cut a coil off of the prokits? Not really sure if that would affect the structural integrity of it. As far as recommending other springs I'm really not sure. I think eibach prokits do a good job of lowering on there own not sure whose springs get lower.
