Front Suspension Conversion
Old Dec 28, 2010 | 11:37 AM
ulakovic22's Avatar
Default Front Suspension Conversion
Is there any reason that a 4th Gen front subframe can't be converted over to a 2nd Gen style with the upper control arm and shock mounting on the subframe? If the shock tower is no longer the suspension mounting point, what structural support does it provide anymore. If it still does add support can it be substituted by tying it into the chassis frame?
Old Dec 29, 2010 | 04:00 PM
Cape T/A's Avatar
Why would you do this?
Old Dec 29, 2010 | 04:04 PM
Sam Strano's Avatar
LS1TECH Sponsor
That's a huge, HUGE step backwards.... like to the '60's....
__________________
Old Dec 29, 2010 | 05:46 PM
ulakovic22's Avatar
Just being creative. The shock towers take up a lot of room in the engine bay.
Old Dec 29, 2010 | 05:51 PM
ulakovic22's Avatar
Why is that? Suspension travel? Chassis stiffness? Aren't the front Corvette suspensions setup this way?
Old Dec 29, 2010 | 09:06 PM
Glenn98ZM6's Avatar
So where you gonna put all those suspension parts that are in the shock towers once you remove them?
Old Dec 29, 2010 | 10:58 PM
ulakovic22's Avatar
I figured the UCA and upper shock eyelet could be mounted to the top of the subframe.
Old Dec 29, 2010 | 11:00 PM
hiltsy855's Avatar
http://https://ls1tech.com/forums/suspension-brakes/982900-has-anyone-converted-short-front-spindle.html
Old Dec 29, 2010 | 11:18 PM
ulakovic22's Avatar
Thanks for the link.
