ls1 brake fitting to AN adapter?
does anyone sell an adapter that will let me mate it to a -3 AN fitting?
Im thinking of going ls1 brakes in front and my line has a 3 an female fitting.
thanks
http://www.jegs.com/i/JEGS+Performan...00785/10002/-1
Not sure which way you wanted to go ...
http://www.jegs.com/i/jegs+performan...00785/10002/-1
not sure which way you wanted to go ...
http://www.google.com/products/catal...d=0CEoQ8wIwAA#
If you want to convert it to AN, you will need to get an adapter w/ a crush washer or a banjo to AN fitting like these:
http://www.google.com/search?hl=en&t...f&oq=&gs_rfai=
The 2nd link will allow you to use the OEM banjo bolt and crush washers.
i just looked at the stock bolt and for some reason I dont think it is flared.
here is my question, since I have the stock bolt, will this fitting work?
http://www.summitracing.com/parts/EAR-997631ERL/
The benefit is that the a straight ended brake line will leave the caliper perpendicular to the caliper and won;t get into the wheel or tire.
