stock at 100k
Also, it might be good to check your bushings/tie rod ends/ball joints/etc. to make sure everything is in good shape. Finish things off with an alignment and you should be good to go!
A bigger front swaybar with the stock out back will cut a ton of body roll, but the rear feels slow and lazy to react that way. I've tried it, and I really did not care for it. If you're going to do swaybars (which are a great upgrade) definitely get a nice matched front and rear set. When I added the rear bar with the front 35 it felt worlds better than with the stock bar out back.
Also as posted, no you don't need adjustable lower control arms. If you do, something is wrong. And no you don't absolutely need adjustable shocks. I've run bilsteins with lowering springs and would rate them as decent. Koni's are the way to go if you have the money, but bilsteins are okay.
If you don't care about lowering, bilsteins and strano or UMI bars (front AND rear) is a very good setup
I just got my Bilsteins from Strano and I can't wait to put them on. I had KYB AGXs on my previous Camaro and it made a huge difference from the stock DeCarbons with 60k miles, so I'm expected a bigger difference with the Bilsteins replacing the stockers on my 100k mi. LS1.
