c5 vs ls1 pads
c5 vs ls1 pads
Is there a size difference between a c5 pad and ls1 brake pad? Im getting ready to pull the trigger on a c5 conversion but I want to keep my ls1 calipers. I might be going w/ the J&M brackets as they dont require any cutting in case I'd like to go back one day. Thanks guys for any help
LS1TECH Sponsor
LS1 and C5 pads are almost identical in size. You don't gain a bigger pad with this swap. Event the calipers are pretty much the same, though the C5/C6 stuff is a little stiffer and you get the slightly bigger rotor if you are in dire need of shedding more heat.
Generally I recommend a nice set of pads, lines, fluid for the stock LS1 brakes. That's fine for most folks who aren't open tracking the cars a lot.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
As valid a reason as any. If you need help on the pads, rotors, etc let me know. I do have the UMI brackets as well (I know, I know they're not on the website--only so much time in the day...)
__________________
