Brake Pads...
I find the HPS to be a great all around pad. ATE pads are really nice. HP Plus stop like freight trains but are dirty and squeal prone. I have PowerStop Z16's too, which work well, but don't have quite the power of the HPS. Anyway, I've got options!
(I was going to check your site for this info but it looks like it's down.)
)....Sam put his opinion in there as well I believe. From reading, it seems that the HP+ stop shorter than the HPS, but the HPS is a lot more street friendly. Trying a search for particular pads might net you a lot of results as well.(As far as the site, I don't believe hard numbers are on there, but I'm having trouble with the site as well!)
HP Plus do have more bite. They grab harder, and faster.... but HPS aren't weak, just what I consider more driveable/liveable.
...haven't tried the hps though....
I would say 98-99% of ppl on this board would be very happy with HPS pads. I still use them on the rears, actually.
What we want for good autox pads is exactly what you want from good street pads. You want them to work without being hot. You want good bite, you want good linear torque curves.... I sell a lot of different pads, and some of my best friends run HP Plus, but I find them a little too abrupt in their action. I can live with the dust, and the noise but they are a little too on/off for me. In fact if you want more than HPS power, I'd put you on DTC-30's instead (which I also have). They have HP Plus kind of power, work cold, but are easier to modulate and have a more HPS like torque curve.
The ideal street pad should be predictable and linear across the entire temp range. My favorite pad is the powerstop z16 ceramics. They work well at low temps, grab amazing with some heat in them and refuse to fade even after repeated high speed highway stops. They're also virtually dust free and silent. You also can't beat the price, Hawk can't come close to touching the value of powerstop pads.
A F/R Set for f-bodies is only $90.00 shipped.
anyone ever use the duralast Gold brakes? dumb i know. The weather will finally be nice and want to do the brakes just havent settled on a set of pads yet.
