Shocks/spring question
Old Feb 6, 2011 | 04:22 PM
justin hover's Avatar
Default Shocks/spring question
I've read alot about first suspension mods being shocks....well I want them...soley daily driving, never street race...just looking for a cheap fix for a upgrade. I'm looking at either TOKICO 330$ set of 4 or kyb for about 400$. Maybe some blisten, but I don't want to spend so much just on shocks. and... can I just keep the stock springs? or is it HIGHLY RECCOMENDED to replace those as well...(cheap, but better than stock) all I'm looking for.. so please no koni responses..
Old Feb 6, 2011 | 04:29 PM
Cheap Guy's Avatar
I had KYB AGX shocks on my LT1 Camaro and it made a huge difference in handling. I didn't change springs because I worried about the ride height, especially on rough Michigan roads. A couple of years ago, the KYBs were cheaper than Bilsteins but now they're about the same price so I'm going with Bilstein on my new LS1, again going with the stock springs.
A lot of times people go with lowered springs for looks, not handling.
Old Feb 6, 2011 | 04:34 PM
So theirs really no need for springs then? The price of the TOKICO (SET OF 4)are fking great though. I just wish I could read more threads about people running them...and I know exactly what you mean about michigan roads...pot hole city..
Old Feb 6, 2011 | 04:51 PM
Cheap Guy's Avatar
I think the reason why you won't read much about the Tokico shocks is because most people either go with Koni shocks (if they can afford them, especially if they're lowering their cars) or Bilsteins. Some people in the past used KYB AGX as the "poor man" substitute for Konis when using lowering spring due to the adjustability of AGXs.
These cars have been out so long that certain parts have been proven to be either the best or most cost effective solution for specific problems. I think shocks are one of those areas:
1. Koni (if you can afford them and want the "best" or if lowering your car)
2. Bilstein
3. KYB AGX as a cheap way to go if you need/want the adjustability needed for lowering.
Old Feb 6, 2011 | 04:59 PM
ok...I will never lower the vehicle...so no need for adjustable right? I'm ordering off the ws6 store so point me in the right direction please... 93-02 SLP Bilstein Shock Package #70008 this is the one right? and that's all I need? no other componets for the install? tks man...by the way ...99 ta auto.
Old Feb 6, 2011 | 05:48 PM
pewter2002's Avatar
Just bc you will never lower the car does not necessarily mean you won't benefit/want adjustability. My point is that an engineer/susp guy at Bilstein/Tokico etc. decides how much dampening your chassis needs, not you. They want to make a shock that will satisfy most of their potential customers or the product wont sell and be labelled as junk or poor performing. That being said, I've had the SLP Bilsteins and found them great. There were, however, times I wanted more dampening. If I had to, I'd go back to the Bilsteins (I now have Konis) in a heartbeat. These shocks were such a step up from stock I would suggest to anyone that they are worth it.
Old Feb 6, 2011 | 06:02 PM
jim ravencraft's Avatar
Exclamation
hi,
you can check with mr. sam strano or other vendors. they are reputable and will enlighten you on your needs. the shocks/struts will make alot of difference in the ride/handling characteristics of your vehicle. this is one of the best mods you can do and expound as money allows$$$$$$.have a blessed day and good luck......please use caution and safety equipment
when working on vehicle
Old Feb 6, 2011 | 06:06 PM
Cheap Guy's Avatar
^^^^Like said above, give Sam Strano a call or email, he's a site sponsor and I found his prices were the best.
Old Feb 7, 2011 | 12:32 AM
elwood2's Avatar
I'll be getting these when i have the money. Hopefully soon, mine bottomed out twice earlier on these rough roads around here!
Old Feb 7, 2011 | 10:15 AM
z28bryan's Avatar
Bilstiens are much better quality than Tokico or KYB and about the same price as the KYB AGX. I think they are a little less than 400 actually for a set of 4 SLPs. I'm pretty sure you can't go wrong with the Bilstiens and stock springs.
Old Feb 7, 2011 | 12:19 PM
Sam Strano's Avatar
LS1TECH Sponsor
Bilstein are definitely the best choice of the KYB, Tokico, Bilstein three... I have plenty in stock, they are $384.99 plus shipping (which isn't much to Michigan from PA)... $405 to the door most likely, if you are around Detroit, a little more if you are further away.
__________________
Old Feb 7, 2011 | 01:05 PM
Hey Sam, I looked you up last night and read alittle about you. Sounds like you now your sh*&. This is where I'm at. With the 2:73s I have now, I have wheel hop. The new gears 3:73s should be here tommorow. Installed within this month. I'm pretty sure the wheel hop will not get any better with the new gears in...I was going to do a poly/roto LCA and relo brackets to start, then probably shocks...I wanted to do it that way first because of budget purposes, and I really just want my wheel hop issues to go away..I will be ordering from you though. What would you suggest as far as lca's and shocks? This car is soley a daily driver, never track it or street race. I do occasionally GET IT from stop light to stop light like everyone else but that's about it...Your blisten slp package sounds about right for me.. thanks...(oh yeah, 99 ta auto...275 tires )
Old Feb 7, 2011 | 01:19 PM
Sam Strano's Avatar
LS1TECH Sponsor
You're right the gears won't help the hop much. But the shocks could be a huge part of that issue especially on Michigan roads with the heaves and bumps.
I can do the LCA's and brackets too.... Given the miles I'm guessing are on the car, I'd have to say shocks first as they will help in a lot of ways--even with the hop to some degree, but you might well need the arms anyway.
I'd do Bilstein's. I like the poly/roto-joint arms a lot because the roto's allow good articulation with bumps and ruts... And brackets--that's up to you. If you are not lowered, I'd not recommend them.
__________________
Old Feb 7, 2011 | 03:38 PM
sounds good sam....the car has about 49,000 miles on it...just got it last year. That's why I DIDN'T think shocks had anything to do with it, but after tons of forum reading I'll def. upgrade. it wouldn't hurt. Problem is money. I got a ws6 hood and gears. The total with installs is about 1800$ it really only leaves me with about 200$ for now, and with that, I thought the lac's for the simple fact that I have wheel hop. I would hate to get the shocks first, and still have crazy wheel hop, and then be forced to get the lca's and go way over budget...ya know.. If the lca's cure the hop, I'll hold off on the shocks until mid summer oil change...but if I continue having hopping issues I'll just get the shocks right away...even if I do break the bank alittle. I will call you at the end of next week for the LCA order for sure...and thank you....
Old Feb 7, 2011 | 03:42 PM
Sam Strano's Avatar
LS1TECH Sponsor
Well, if it was a WS6 you'd have better shocks, but still not great. And remember that they've got the miles equal to having been around world twice now.
I get the money part... but I guess it comes down to priorities. The shocks should help hop but might not cure it. Honestly LCA's might not cure it. Then again, either/or might. The advantage to shocks is the car will ride and drive better in other ways.
__________________
Old Feb 7, 2011 | 03:47 PM
forgot to tell you....the wheel hop....If i'm on a perfectly paved road...I floor it from a stop...it hops..the low trac light comes on...kinda feels like I loose power....really pisses me off cause, someone will say "BURN'EM" and...i can't(unless it's raining)
Old Feb 8, 2011 | 08:44 AM
z28bryan's Avatar
That's how it usually goes. Various combinations of shocks, lcas, relocation brackets, and torque arm upgrades can help cure wheel hop.
Old Feb 8, 2011 | 11:07 AM
Just ordered from sam......shocks and lca's yyyeeaahhh mmmannn...
Good man....description of products is undeniable....
Old Feb 8, 2011 | 11:10 AM
pjb's Avatar
pjb
turn your traction control off.
Old Feb 8, 2011 | 12:30 PM
I never turn the traction control on. It's just when it hops the low trac light comes on, and then goes away withen a second or 2.
