BMR Lower control arms with rubber bushings!!!
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
Many people don't realize it but we have a rubber bushing option for any of our lower control arms that use our poly-urethane bushings. The is an option that can be done with part numbers BCA001, TCA001, MTCA001, MTCA002, and TCA004. There are a few guys on the board who currrently have this option on their BMR lower control arms, but I want to make sure everyone knows. Here are a couple of pictures with our TCA001 and MTCA002 with the rubber bushings. If anyone has any questions just let me know and I will answer them.
Thanks,
Kyle
Thanks,
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Kleeborp the Moderator™
Is the option available for purchase through your website? I had to call to get mine...not that it was difficult or anything, but it would be even more convenient if they were listed as an option online.
Regardless, I really like mine. Thanks for having it as an option. And thanks for having that chick in your sig. She's hawt.
I hope to have some new picture pretty soon!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
That is why most guys take advantage of the rubber bushings. They are dead quite and still perform a lot better than the stock arms.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
I wouldn't use these to race with in a 9 second car, the rubber just won't handle the abuse like a poly-urethane bushing or rod end. Since the bushings are rubber there is some deflection in it which will allow for unwanted movement on a car with that kind of power.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Young you are so awesome, I will remember this next time you need something!
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
LS1Tech Premium Sponsor
To further point out some perks of these bushings I figured I would show some additional data on our rubber bushings. First, the bushing is not actually rubber, it's manufactured from neoprene, a rubber substitute with many advantages over rubber.
From DuPont's website:
"Neoprene polychloroprene is an extremely versatile synthetic rubber with more than 75 years of proven performance in a broad industry spectrum. It was originally developed as an oil-resistant substitute for natural rubber. Neoprene is noted for a unique combination of properties, which has led to its use in thousands of applications in diverse environments."
A Balanced Combination of Properties
As you can see below our polyurethane is formulated to a 90 durometer while the rubber is just under 65, almost identical to what the 1LE bushings measure. This allows more articulation than the polyurethane yet the smaller diameter of the bushing prevents excess deflection when loaded.
- Resists degradation from sun, ozone and weather
- Performs well in contact with oils and many chemicals
- Remains useful over a wide temperature range
- Displays outstanding physical toughness
- Resists burning inherently better than exclusively hydrocarbon rubbers
- Outstanding resistance to damage caused by flexing and twisting
![](http://www.bmrsuspension.com/ForumImages/durometer.jpg)
It's a fairly simple instrument. There is very small pin that protrudes from the bottom of the gauge. The gauge is calibrated to work on materials of this nature and as you can see it only scales 0-100. When the needle is pushed against the rubber it collapses up into the instrument. At the point where the instrument bottoms out against the object being measured, you take your reading.
Can I just purchase the rubber bushings seperately? I've searched everywhere and this is the first time i've seen anyone selling rubber bushings for aftermarket rear control arms.
These bushings can be purchased seperately but they are designed for our BMR LCAs so we can't be positive that they will work with other manufacturer's LCAs. We are about 6-8 weeks out from having these in stock since we are waiting on them to be made from our manufacturer.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
