Want to reinstall ABS module, anybody sell factory style braided lines??
I bought a 1998 Firebird Formula A4 last fall and have finally gotten around to modifying it. The previous owner removed the ABS module and I want to reinstall it but I don't have the factory prebent and braided steel lines. Does any company sell these or am I sol?
Thanks
Thanks
If you want full braided, you can call Earl's and have them made to your specs, but your going to have to know everything about them. Length, End fittings, Thread size and pitch, etc.
If you want original, you'd have to purchase a complete line as the braided section cannot be separated or added unless if you're doing some slight fabrication. If still available, it would be a dealer part. Probably not inexpensive either. You could possibly purchase from a junk-yard, but the lines probably won't be in too good of shape.
I could possibly offer you some of the parts you may need...but you'd have to perform some fabrication on your own.
Post a ad in the wanted section. I am sure there is someone out there who is removing thier ABS and would sell you the parts needed. I plan to remove the ABS very soon but I like to keep all my stock parts just incase.
