questions on installing SFC's & LCA's
Ive got UMI Subframe Connectors (3-point Bolt In) and Adjustable Lower Control Arms with Relocation Brackets. Some questions i got are,
- How long should the install take? And how difficult is this install?
- Is it better to use Ramps or Jackstands to load the suspension in the rear when it comes time to tighten down all the bolts? (was considering buying another set of ramps).
- Do the ramps have to be the same size/height or no, aslong as the suspensions loaded? I can borrow a friends ramps but his are a bit bigger then the ones i have. Reason for me considering getting another set of ramps.
- Do i need to take off the rear wheels for the LCA install?
I dont have the instructions with me right now that came with the parts, there at my parents house. I have an apartment and im about an hour away. Just thought i would ask some questions right now and be prepared for this install.
Kleeborp the Moderator™
Quick question, which way does the adj. lower control arm go? Does the side you adj. go in the rear or in the front where you connect it with the subframe connectors?
