Parking Brake
Are you looking for part #6?
If you unscrew #3, you can wiggle the lever out of the parking brake cable. If you clean everything out good with rubbing alcohol or brake cleaner, you should find #6 in there somewhere. Just liberally lube everything with brake caliper grease and you'll be good to go.
#8 and #9 do come apart. When they are tight against each other, the grease creates some wicked suction also. I had to sit down with them, use brake cleaner to dissolve the grease and eventually they came apart so I could re-lube them.
If you still can't find #6, you can only get it in a full brake repair kit, part number 12454994. RMS Auto parts has a good diagram of what's in the kit. They are also the only place that sells #3 as an individual item. (If you are taking your brake apart, its probably time to replace these rubber boots, as well.)
