Need help with vibration sound
After I put in the 9" I was not able to install the sway bar because of needing to buy the mounting hardware. I installed the sb and now I have a horrable vibration under the center console. It never did it with the factory rearend/sb.
The car doesn't vibrate, just under the center console. I can't figure out why installing the sb would cause this.
The only things that come to mind is the tranny mount or ta mount/bushing?
Any suggestions would be helpful.
Is your rear end feel like it is slidding? If so check the links(what they call it in the catalog) I can give you the part number if you need . I just replaced mine and it seem like it fixed that. You sway bar maybe moving around on you.
