tunnel mnt trq arm and true duals ????
will they fit ? i have the summit true dual x-pipe kit with flowmaster 30 series mufflers under car now . i ran a full length trq arm till now and was wondering if i was gonna have problems with the exh hitting the trq arm mnt ?
LS1Tech Premium Sponsor
Depending on your cross member no, we have a tunnel mount torque arm and cross member combination just for this situation. How ever keep in mind that you limit yourself on pinion angle and if your vehicle is lowered it can be hard to get your -1 pinion angle depending on how low the vehicle is.
This is off a customers vehicle with an exhaust they had done, but it shows you can get it to fit and how our tunnel mount torque arm fits.
![](http://img24.imageshack.us/img24/1637/img00027201009172127.jpg)
![](http://img862.imageshack.us/img862/5206/img00030201009172129.jpg)
I don't recall if their exhaust kit is a custom build or box bought kit.
I used a long torque arm and a trans mount with the torque arm mount on on it. I think it is a umi piece. They work fine, but my exhaust is also custom duals, not a kit. If you have a torque arm that works with the exhaust already, that is probably your cheapest and best route. Looking at that pic, it looks like the driveshaft is hitting the loop.
if i hook hard im nervous about hurtin the trans . i bent 2 stockers last yr lol. drew ya know what the car has esp for trq im just seein if people are usin the spohn tunnels with a true duel kit like mine and if so where the clearance issues are . im not totally opposed to changing my exh around even though i love how it sounds lol
here is the mount that I used with a stock style torque arm. fits fine. good luck
http://www.byunspeed.com/product_inf...oducts_id=7566
How ever the case may be everyone using a drive shaft loops needs to be aware they can not jack up the rear of the vehicle allowing the wheels to dangle as most all drive shaft loops can come into contact with the drive shaft.
There is only so much tunnel room to fit a certain size loop in the vehicles and they are designed for ride height fitment.
ya think i should scrap the exh thats on the car now drew ? lolol and go with a big single or stay t/d with a custom kit on it ? the rearend swap drained me a bit so i dont wanna be buyin a **** ton of stuff lol
thats kinda how my exhaust is at least on the front part of the x-pipe , the only problem i see with mine is gonna be where the tunnel mnt hooks up , and where my x-pipe is after that the room i have is adequite
