DD K1500 brake help
I'm having a hard time diagnosing my issue. Basically I drive all day everywhere (sales), when i have to 'jump' on the brakes quickly the pedal is very hard and does not stop for about 1 second or 2. Then the brakes engage. Truck is a '99 k1500 classic body style. I've had it at several shops. One Chevrolet dealer and one Ford (i have a buddy there). Both tell me the brakes are fine and within "Spec". My wife's 05 tahoe and my 94 1/2 ton do not have this problem and have similar setups. Any suggestions? Sorry for the long read and I know its not LS but I'm lost and everyone here has always had an opinion good or bad.
I have replaced everything, master, booster, all pads front and back, rotors, rebuilt rear brakes, relathed rear shoes, wheel cylinders and bled about 2 bottles through the system, the big ones.
Josh
Josh
Josh
Josh
Also, do you tow a load around with it? Or in the bed?
i own a C2500 suburban (in sig) and like yourself, have had brake trouble since in owned it which is almost 2 years now. although i have hydroboost instead of traditional vacuum brakes, but never could get the truck to stop. idk if your also having a stopping distance problem or not, but i wouldn't be suprised if your problem may lie in the proportioning valve, which is built onto the abs pump on the driver side inner fender. my truck had a similar issue on hard stops, but i also would just smoke the front brakes, blowing stop lights, or have to head for the ditch. i did almost everything you have, minus the master/booster replacement, and i also have the 13x3 1/2 drums on the back, which are the biggest gm used in those days even with a dually (14 bolt full floater rear end). they were adjusted so tight at one point i couldn't hardly turn the rear wheels with them in the air. to not get into a really long story here, i had enough, and i disconnected and removed the entire abs pump, and to my suprise (not really) all the lines into the system had different fittings and such. so i cut them all back about an inch, (there are 5 lines, 1 front input-2 front output, 1 rear input-1 rear output) and i "T" the front lines together, i used a JEGS adjustable proportioning valve for the rear, and also ran from that into a 2lb residule valve to keep just a small amount of pressure on the rear, about enough to keep the wheel cylinders slightly loaded. immediate improvement! that fixed all my issues that i know of. i now have to feather my brakes on hard stops to keep from lock-up, but i'm ok with that, and i have full adjustment for my front/rear bias. before, i really didn't need abs, because it wouldn't have locked a wheel if it had to, i tried (with the abs un-plugged). idk if this would help your paticular situation, but it sure helped mine. if you want some pics just let me know. btw, total cost was around $100.
Josh
Josh
After doing a complete brake service, changing the master, and replacing the booster, my diagnosis has come down to there being a restriction in the system. It seems that there must be a fluid restriction somewhere, most likely in the ABS/Combo unit. One day when we have some free time we are going to bypass the ABS block and see if it eliminates the problem.
