Way to much play in my steering wheel
Old 04-10-2011 | 07:15 PM
LS1TAUTO's Avatar
Default Way to much play in my steering wheel
There's like a inch an a half of play in my steering wheel my cars got 166k on suspension only mods are uni torque arm relocation kit, wat could this problem be??? I'm pretty sure there's a tad of play but not no inch and half
Old 04-10-2011 | 07:45 PM
ramairetransam's Avatar
4 loose bolts in the steering column . They are a bitch to get to and you need special tool , dealership will charge about 250 bucks .
Old 04-10-2011 | 08:00 PM
LS1TAUTO's Avatar
Serious???? Will they make to weres there's no play??
Old 04-10-2011 | 08:26 PM
yeah , its 4 bolts at the waay bottom of the column , they will probably red locktite them in and youll never have a problem again .
Old 04-10-2011 | 09:08 PM
LS1TAUTO's Avatar
Is the dealer only 1 that can do it??? Is this problem common in f bodies or firebirds???
ukg35's Avatar
Let me know if this works for you. I'm having same issue and about to work on it. Good luck.
Old 04-10-2011 | 10:14 PM
Badazz 97 TA's Avatar
could be the rag joint. its a rubber piece that is supposed to dampen vibration. it causes alot of play especially in high mileage cars since its right next to a high heat part. . its under the hood next to the header. its connected to the steering shaft. i would take a look at that before what was suggested above.
Old 04-10-2011 | 10:17 PM
babbage1109's Avatar
Adjust the steering Knuckle?
Old 04-10-2011 | 10:21 PM
Coppertone's Avatar
I had the same problem. I traced it down the the rack and pinioin. After swapping it with a new unit....problem gone, and steering is tight like if should be.
Old 04-11-2011 | 12:42 AM
LS1TAUTO's Avatar
I replaced the rack with my 02 and it had 75k on it about a year ago is it possible that went bad???
Old 04-11-2011 | 01:27 AM
jsteele90's Avatar
double check the bottom bolt on the steering shaft where it goes into the rack. mine had the same problem and i just tightened the **** out of it and that fixed it. no play at all now
Quick Reply: Way to much play in my steering wheel
