Trying to remove front shock. Ball joint spinning. Help!
Im halfway through my BMR spring and bilstein shock swap. problem is on the drivers side i am trying to remove the bolt that holds the spindle to the upper control arm, and the ball joint is spinning. What do i do?
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
usually will come out with some downward pressure using tie rod/ball joint tool. However, vice grips will work as last resort. Replace joints using care to protect boots from damage. I would suggest replacing upper and lower joints and then get yourself a quality 4-wheel alignment. Check joint -by turning with fingers/if shaft turns freely replace.best of luck and have a blessed week....jim
