torque arm worth it?
Old Apr 30, 2011 | 08:21 PM
Davey G's Avatar
Default torque arm worth it?
plain and simple is a torque worth it and what can you expect by installing one?
Old Apr 30, 2011 | 08:46 PM
kicksZ28's Avatar
subscribing
Old Apr 30, 2011 | 08:50 PM
xX-Z28-Xx's Avatar
Subscribing also...
Old Apr 30, 2011 | 09:24 PM
TransWS6Am's Avatar
What vehicle do you have? If it's an f-body you already have a torque arm. Do you mean an adjustable aftermarket torque arm? The one thing i liked about my old SLP adjustable torque arm was just that, its an adjustable torque arm, you can set the correct pinion angle, plus it's much more solid than the crappy stamped steel stocker.
Old Apr 30, 2011 | 09:38 PM
BOLO's Avatar
It really depends on what you plan to do with your car. Track? daily driver? I'd leave it alone if it's your daily driver.
Old Apr 30, 2011 | 11:41 PM
rabbit320's Avatar
its amazing! yes get it, i drive it daily and it handles awesome... check out my thread, ill bump it up around this one, for more detail how it feels... but it really depends what you have already...
Old May 1, 2011 | 06:59 AM
bayer-z28's Avatar
After I did mine it just felt like it transferred power a lot better. Took some slop out of the driveline.
Old May 1, 2011 | 08:48 AM
Davey G's Avatar
Mine is a daily driver and I think at this point I have every bolt on that you can do to the car.
Old May 1, 2011 | 09:03 AM
02SOMLS1WS6's Avatar
I just ordered a UMI adjustable, I will let you know my impressions of the new arm after I get it on the car. My car is lowered with G2 springs so I am sure if nothing else getting the angle back to optimum will make a difference in feeling and traction.
Old May 1, 2011 | 11:45 AM
HoLLo's Avatar
I agree with this guy.
I installed one simply because my stocker broke at the mounting points on the rear. I never take my car to the drag strip, but on the street, you can notice a big difference. Probably the best rear suspension item I did.
Old May 1, 2011 | 02:01 PM
skopers3's Avatar
Next to headers, a torque arm was my most noticable mod. I'd consider it a necessity.
Old May 2, 2011 | 01:14 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
It is definitely worth doing! I have seen many guys tweak the stock torque arms since they are just stamped steel. The torque arm definitely gives the care a more solid feel and helps with overall handling both street and track.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old May 2, 2011 | 01:15 PM
DANZWS6's Avatar
are you sure about that???
Old May 2, 2011 | 04:22 PM
Iwannagofast!'s Avatar
I'm getting a UMI torque arm soon. The stock ones are made out of flimsy stamped metal, and actually my torque arm bolts somehow came loose and starting shaking the car on deceleration. Kinda weird... but anyway, a good friend of mine has an aftermarket torque arm on his car and swears by it. Said it helped him some at the drag strip, and the car felt more 'solid' after he installed it.
Old May 3, 2011 | 04:35 PM
unknown pontiac's Avatar
mine just broke. I'm getting one as soon as I know which to get, short one or full size one. I will see for my self if its that much better.
Attached Thumbnails torque arm worth it?-imag0436.jpg   torque arm worth it?-imag0435.jpg
Old May 3, 2011 | 08:35 PM
HoLLo's Avatar
^ Mine did the same thing. I broke mine after practicing some launches on my brand new 315 Toyo drag radials..
