UMI Torque Arm Hardware question
Hey Guys I was just about to order the UMI Tunnel Brace Mounted Torque Arm w/ DSL - Long Tube Header Set-up when I noticed this disclaimer at the bottom of the description..
"If you are running a Moser Engineering 12-Bolt rear-end this kit is not needed, you must reuse hardware supplied by Moser Engineering."
Well I am in fact running a a Moser 12 Bolt rear end and now I'm wondering what the diffrence is in this hardware and the hardware that can be purchased with the kit. I'm wanting to use all brand new parts when I do this install so do I need to contact Moser for this hardware or can something else be used?
LS1Tech Premium Sponsor
With the Moser 12 bolt there are four bolts that mount the torque arm to the rear end (2 thru the top side of the TA bracket and two thru the bottom side of the TA bracket), where as the 10 bolt, 9 inch, and Dana 60 all use two bolts long thru bolts to mount the torque arm to the rear end.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
