Adjust Rear Coil Perch with internal Bumpstop
The adjustable spring perch you can get from any circle track supplier. Its made by AFCO. its about $35.00 for a pair. Its around weight jacks etc. Race Car Engineering even sells a generic one for about $25.00. I the welded a plate on the bottom to help it sit on my 12 bolt. I then welded a plate halfway down the inside thats threaded in the middle to take the bumpstop mounting bolt. This allow the height of the bumpstop to be adjustable as well as the ride height.
The springs are 5x11 Hypercoils I currently have #175's but I'm thinking of trying #150's. They go for around $90.00.
I then have vibration isolators up top from energy suspension part #9.6107 $18.00
The bump stops are part #9.9143 Can remember maybe $25.00
There you go.
This my stance, I will probably drop it another 1/4" front and 1/2" in the back.
There you go.
Is this the coil spring spacer that you used? I gues you trimmed the sleeve off completly and then welded the plate in its place right?
http://http://www.summitracing.com/parts/AFC-20192/
Very cool. Hows the ride quality compared to the stock bump stops? I wonder if this will dent the body/spring perch area when it contacts it, or possibly bend or crack the perch on the axle over time?
Yes
Ok to address the last 2 posts. I can't imagine the poly urethane piece denting the upper spring perch. Remember it is designed to cushion the blow. A good suspension is designed to make the bump stop compression part of the design. This style has much more travel/compression. I up until this point I don't think I sufficiently contact the bumpstop, one of the reasons I'm going to give 150# springs a try. PS my KONI DA are set to full soft comp and 13/4 in for rebound.
Regardless thats a cool setup, please keep us updated with it.
