can you compress the front springs while still installed
Can this be done? I need to compress my springs more i did not do it enough the first time when installing my QA1's. Is there any way to avoid taking them back out.
LS1Tech Premium Sponsor
Just use a spanner wrench and some muscle and you should have no problem adjusting the ride height using the adjustment nut on the body of the shock.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
1 Post
yes, you can do it, depending on how big your spring compressors are. i tried doing that on my spring install, but found it was more of a PITA than it was worth because you have to keep lowering the car to the ground to check your height. I just bit the bullet and muscled through it.
you could just do it to help you initially get to 'almost there', then muscle through it for the last inch of fine tuning.
to give you a rough guideline, i did BMR 1" drop A-arms (AA020) with strange shocks and 300lb springs. the spring perch is around 1" from the top of the threads to make it even with the BMR springs i put in the back. it actually still needs to come up about 1cm in the front to make it perfect (it settled a bit after i drove it).
dont use the stock shock as a guideline, or your car will be ON the ground
