ABS delete, with no line lock?
I need some help installing my SJM ABS delete. It is a 3 channel delete, and I am not going to run a line lock. How do I install this thing? Directions and pictures with the directions both seem to lean towards if I were going to run a line lock?
I don't have an SJM kit, but have installed my own, cobbled together ABS delete.
The front port (furthest from the firewall) feeds the rear brakes through a prop valve.
The rear port feeds a "T" and then goes to the left/right front lines.
I hope that is enough info put the kit together.
