F-Body front hubs
Old 06-11-2011, 12:07 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Default F-Body front hubs
As I found a few people that said they were decent, I bought and installed a pair of new front hubs from ebay. They were like ~$120.00 for the pair, far less than AC Delco/GM hubs at like $240.00 EACH.
After a few months and several thousand miles, one of them is definitely shot, I'm sure the other one isn't fairing well either.
Are there any other reasonable alternatives to buying GM hubs?
Has anybody figured out a way to lube or maintain these hubs?
Old 06-11-2011, 12:49 PM
Paul Bell's Avatar
Another question:
Who makes these hubs for GM? I see that Timken makes a hub, number 513090 and it's supposedly US made at around $125.00 each.
Old 06-11-2011, 02:22 PM
sjsingle1's Avatar
seems SKF and timken are the only players outside of GM
Old 06-11-2011, 11:04 PM
Red98Devil's Avatar
+1 for Timken...
Old 06-11-2011, 11:57 PM
Paul Bell's Avatar
Thanks fellers. Due to the amount of fakes in the market (no doubt the ebay ones are cheep Asian knock-offs) I'm gonna order a pair of the Timken hubs from an authorized Timken dealer in person. There's a parts shop near me that I've used in the past-a pro shop, not a Pep Boys/Auto Zone type place.
Old 06-12-2011, 01:43 AM
roy
roy's Avatar
Autozone Also stocks the Timkins for Fbodies.
Old 06-12-2011, 02:58 PM
leadfoot4's Avatar
+1 for the SKF......
Old 06-12-2011, 11:07 PM
Save the manuals!
wssix99's Avatar
I've had the Timken's on for a couple of years now and they are going great. BTW - The Delco hubs are probably either Timken or SKF... you just pay more for the name on the box.
Old 06-12-2011, 11:40 PM
SparkyJJO's Avatar
RockAuto is a good place for stuff like that.
Old 06-13-2011, 07:28 AM
EchoMirage's Avatar
theres no way to maintain the hubs. the best quality are stock GM. any and all aftermarket, regardless of brand, wont be as good as OEM. a quality aftermarket will typically hold up well with regular street driving, but if you ever do any kind of racing, ie: autox or track, theyll wear out sooner then later. what i usually do is find used GM hubs, clean them up, and use them. even a used OEM hub will last longer then a brand new aftermarket when raced.
Old 06-13-2011, 08:35 AM
roy
roy's Avatar
I disagree Echo.
The Timken Hubs and the factory and or factory replacement hubs last about the same. At least with the experience that I have seen. Got 12 sets here that tell the story. 3 sets are factory replacement and 9 of them are Timkens from Autozone. Including the original hubs from the car, all of them have the same exact markingsin exactly the same place. Which leads me to believe that Timken is a supplier for these hubs to Chevrolet sells.
Old 06-13-2011, 08:50 AM
Ruthless909's Avatar
How would I know if my hubs are shot?
For a few months now I have some sort of humming noise coming from the left side of my Z28 when driving over 45mph. The faster I drive the louder there is humming
Old 06-13-2011, 09:13 AM
MrDude_1's Avatar
damn Roy, thats alot of hubs!
i know a few guys on frrax were working on making a bolt on spindle that could take replaceable bearings, like a 3rdgen fbody can.. but i doubt they would be "legal" in Germany... then again, if they look stock, who can tell the diff???
Old 06-13-2011, 10:02 AM
spy2520's Avatar
i have 12 year old factory hubs on my car. Still tight, no noise. Even after an accident on the left front broke the steering knuckle the hub was still good. So i have two extra used hubs i'll be putting on when these finally go.
Old 06-13-2011, 05:45 PM
leadfoot4's Avatar
Originally Posted by roy
I disagree Echo.
I agree....
GM does NOT make all of their own parts, they set specs, then send out for quotes on parts, made to THIER specs. Aftermarket, well the "specs" could be anywhere between here and there, mostly dependant of the price of the part (we ARE in a price competitive market, you know), or the reputation of the supplier.
Plus, GM, like many other large corporations, has their "suit tax' added on to their parts, to cover the cost of all the execs and middle managers. That's why a GM equivalent part (say Timken or SKF) from a parts store, will be significantly less money. You took out the middleman, in this example, the GM parts network.
Bottom line, if and when my car needs hubs, they will be SKF hubs, p/n BR930186, priced at $142.24 at JBR17llc.com
Old 06-13-2011, 06:38 PM
SS LeadFoot's Avatar
I bought a set of Timken and still havent installed them yet. I looked and looked for other options, but non at all. Can't wait to put them on.
Old 06-13-2011, 06:40 PM
Paul Bell's Avatar
This all sounds pretty good guys, thanks everybody for sharing your experiences and ideas.
I'm gonna wander into an Auto Zone and have a look at their Timken hubs.
Is there any way to determine that it's a genuine Timken and not the cheep Asian knock-off?
Until this thread, I hadn't found any threads discussing the quality, pros and cons of aftermarket hubs.
Old 06-13-2011, 06:44 PM
BrianSF-GA's Avatar
So what kind of mileage and time before everyone is replacing front hubs?
What are the symptoms for replacement?
Old 06-13-2011, 08:43 PM
SparkyJJO's Avatar
Mine had 161k on them and had no problems. They are now on another car (LS1 style spindle/brake conversion on an LT1 car).
Old 06-13-2011, 09:10 PM
BrianSF-GA's Avatar
Yea, that's what I thought ... many many miles before these fail. I am not worried at 80K.
Quick Reply: F-Body front hubs
