best brakes for a 17" Rim for the price?
What is the best track/street brake kit for the front for a 17' wheel
i have looked at BAER WILLWOOD AND BREMBO
but i only have about 1500 at most to spend so some ones personal experience would be help full
C5 or C6 front brakes give you a bigger diameter rotor, which improves braking significantly. Just need the calipers and brackets from the donor car and a set of adapters. Do a search on c5 brake and see what you think. Less than $1K usually.
i agree with the bigger rotor but c5 to ls1 caliper is no difference there clamp pressure/bite is the same i want to move to a minimum 4 piston caliper
do you have a part number that you used for the willwood kit?
On another note there are a few guys that have been using the 2010 Camaro SS calipers and 14" rotors, but 18" wheels.
My kit number is #140-10691
The 13" kit is #140-7190 (technically a 12.88" rotor, but the offers a much better caliper than the 13.06" kit which is #140-9833)
PM me if you want more info.. I also have a connection for Wilwood if your interested.
All that being said, I track my car quite frequently and the 12.2" kit is more than sufficient with good pads, both on and off the track.
Im running a the 12.2" setup on my car. It came from a buddy that races in CMC2 and they are limited to nothing larger than a 12.2" rotor.
