Back to the 4x4 look
Old Jul 17, 2011 | 08:58 PM
TransWS6Am's Avatar
Default Back to the 4x4 look
I swapped my Eibach pro-kit out for Strano springs this weekend. I was going to leave it in the air until i recieve my kooks true duals this week (I hope). But I couldn't wait, so I just went outside and put it back on the ground. WOW! it looks like stock springs. I don't think it helps that a have a MWC 9", I know that brings the rear end up like 1/4" give or take, and negative pinion angle also brings the rear up alittle. But the front is noticeably higher than the Eibachs. Oh well Atleast I can fear speed bumps less and not bottom out as much, and the strano's will give me alittle more room for the kooks pipes to go over the axle. The strano's did provide a slight rake with the front being lower than the front (so did the eibachs) but again, I know my rear end comes into play again. How much to strano springs "settle" I know they are said not to sag, but do they settle at all with some driving? Strano Pics to come tomorrow
Eibach pro-kit with stock 10 bolt
Eibach pro-kit with MWC 9"
Strano's with MWC 9"
Old Jul 17, 2011 | 09:51 PM
02TransAm/Batmobile's Avatar
Kind of hard to tell the difference. Do you have a full-on side shot like picture number 2 with the MWC 9? I wasn't too happy with the ride height with my Strano's when I first installed them. Now I am perfectly happy with the stance as it has settled.
Old Jul 17, 2011 | 09:56 PM
TransWS6Am's Avatar
No unfortunately I do not, I only had the Eibach/MWC 9" for 100 miles, so Those are the only pictures I have. That's good to know they settle some.
Old Jul 18, 2011 | 02:38 AM
BlkBird2000's Avatar
Here are my strano and koni 4x4 on a moser 9". The rear does sit a little higher than I like but that may look like this because the rear tires are 315/30/18.
Old Jul 18, 2011 | 07:17 PM
TransWS6Am's Avatar
Pictures of the strano stance added.
Old Jul 18, 2011 | 07:18 PM
TransWS6Am's Avatar
looks pretty similar to my stance, but yours seem a little lower in the front.
Old Jul 18, 2011 | 10:40 PM
JD_AMG's Avatar
That stance looks perfect to me, remember these springs are about function and performance, not looks.
Also that is FAR from the stock 4x4 stance... Look at what my car looked like when on stock springs vs strano springs:
Uploaded with ImageShack.us
Old Jul 18, 2011 | 11:15 PM
Latch's Avatar
Your car looks fine. A little rake looks good. I wouldn't worry about it.
Old Jul 19, 2011 | 12:05 AM
Looks good actually. I never liked 315/30R18 tires because they always looked too thin for me. It seems to work on your ride for some reason.
Is this with or without the rear isolators?
Old Jul 19, 2011 | 12:25 AM
WS6sleeper's Avatar
How does the mwc 9" raise the height???? Do all aftermarket rears raise the height a little?
Old Jul 19, 2011 | 12:49 AM
The springs sit on a much thicker axle housing.
Old Jul 19, 2011 | 10:46 AM
airforcemanss's Avatar
to the OP, are the isolators removed in your pics?
Old Jul 19, 2011 | 10:52 AM
TransWS6Am's Avatar
no, the isolators are installed in all of the pictures.
Old Jul 19, 2011 | 11:03 PM
Camaroking1996's Avatar
some 18's would close up that gap a little
Old Jul 19, 2011 | 11:08 PM
Not entirely true. Let's say you jump from a 17x9 to a 18x9. The recommended tire of choice for the 18x9 is a 275/35R18 which is the closest to stock. The 18" tire choice is actually smaller than the 17" (25.58" vs 25.66"). Rim size alone is not the deciding factor but tire size is.
That's why I went with a 295/40R18 (27.29") to fill up the wheel well area.
Old Jul 19, 2011 | 11:15 PM
baalic's Avatar
To op. Is that factory paint?? It looks pearl... If it's factory what polish/wax do you use. Your cars gorgeous!
Old Jul 20, 2011 | 06:19 AM
TransWS6Am's Avatar
It's Cadillac pearl white.
Old Jul 20, 2011 | 06:08 PM
99FormulaM6r's Avatar
I think lowering the rear about 1/2" (heater hose mod?) would settle it out to perfect IMO. As it is, I think it looks better than with the Eibach setup. Just if I was picky, I would lower the rear a tad.
Old Jul 20, 2011 | 06:30 PM
TransWS6Am's Avatar
I'm going to see what my exhaust clearance over the axle is like once i get the kooks duals installed. If there is room then I may consider the heater hose mod.
Old Jul 20, 2011 | 06:33 PM
TransWS6Am's Avatar
I'm doing a mini tub next month in preparation for some wider tires. I'm looking for a set of 18x13 to put on next spring. I'm really considering the 18" WELD RT-S with high pad clearance, but I wanna see them on another f-body first, if anyone would ever order them!
