question about lca relocation brackets
i was planning on installing my tubular lca and bolt in brackets this friday, but now i'm not so sure about the brackets. the car is an lt1 at stock ride height. i was curious if i could get some testimonials from yall to see if its worth it, or if i should just sell them. the car is my dd and it has yet to see a track, drag strip or otherwise. just trying to improve straight line traction for the few instances of spirited street driving i do. at the same time though i dont want to have to worry about fishtailing when it rains and such. any info would be great. thanks
-Jake
The whole point of the relocation brackets is to correct the LCA geometry when the car is lowered. Putting them on a stock ride height car will likely induce more problems than anything.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
It was ******* scary! Imagine me yelling that and you will have an idea. I coudln't keep the car on the road. I was winding it up on the highway in a slight curve one afternoon. I hit 4th gear at 100mph and the car changed lanes on it's own. I moved them back to the lower hole and everythings fine again. I do have an adjustable T/A and its moved up one hole too to help the center.
I am not saying do or don't buy these, I know every car is different but just make sure they are setup right.
Glenn ***
Sales Tech
813.986.9302
I'm at stock height,because of a deep tranny pan and driveshaft loop and do a lot of travelling(and you never can tell what you're gonna encounter in bumps and uneven surfaces),and have always used the lowest holes for maximum straightline traction.
Trying to take off/accelerate in snow also improved.
Glenn ***
Sales Tech
813.986.9302
I generally try to get people to go ahead and do the adjustable LCA's because it is never a bad thing to have the adjustability and plans always change so it is nice to buy one arm that can be used in pretty much all situations.
Glenn ***
Sales Tech
813.986.9302
