LCA Relocation Brackets
Old Jul 27, 2011 | 07:46 PM
jasonz28camaro's Avatar
Default LCA Relocation Brackets
my question is... there are 3 postitions on the relocation bracket and i want to know what position to use. there is stock, middle and closest to the ground. my car is dropped 1.25".
any thought would help, i just dont want to keep moving it around and my car does not hook anyway, need DRs.
Old Jul 27, 2011 | 07:48 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
what position are you using now ?
https://ls1tech.com/forums/suspensio...-brackets.html
Old Jul 27, 2011 | 07:50 PM
lowest to the ground
Old Jul 27, 2011 | 07:54 PM
i read that entire post and did not find my answer before i posted, its not in there or im stupid lol
Old Jul 27, 2011 | 09:21 PM
95killerz's Avatar
I would say if you're lowerered than the lowest hole is probably the right one to use. I remember reading a post that said the lca's should be around 4 degrees
Old Jul 27, 2011 | 11:37 PM
01ssreda4's Avatar
Use the lowest hole.
Old Jul 28, 2011 | 07:52 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Definitely use the lowest hole since your car is lowered. It looks like you may be planning one day to make a bunch of power and when that time comes you may want to move irt up a hole but for now keep it in the lowest.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jul 28, 2011 | 11:06 PM
jarretthise's Avatar
what exactly is the advantage of having relos?
Old Jul 28, 2011 | 11:37 PM
meine96ws6's Avatar
They allow to tune in the "instant center" of the chassis, helps to properly align the suspension after lowering the car.
They helped to eliminate my wheel hop... just saying..they are worth the money.
Old Jul 29, 2011 | 07:47 AM
BMR Sales2's Avatar
Not only does it do everything that Meine96ws6 said but it also adds positive anti-squat to the car which helps keep pressure on the rear tire and in turn really helps with traction. The lower control arm relocation brackets are definitely worth the money to do.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Jul 31, 2011 | 01:00 PM
trans_am7935's Avatar
so are they worth it to someone with a stock ride height car and non adjustable LCA's?
Old Jul 31, 2011 | 01:27 PM
yes,if you want to increase launch traction.
do the bolt-ins variety so you can remove(you won't want to after you feel the better launch traction)if you want.
Old Jul 31, 2011 | 01:45 PM
now just to verify, i have solid UMI LCA's and i would like to keep them, is that going to be a problem with using LCA drop brackets?
Old Jul 31, 2011 | 01:50 PM
metalmilitia606's Avatar
Shouldn't be a problem. You can use them with the stock lca's so with your aftermarket ones the brackets will only help you.
Old Jul 31, 2011 | 01:56 PM
sweet, i also read that these brackets make it easier to break the 10-bolt at the strip, is this correct?
Old Jul 31, 2011 | 03:23 PM
increased traction with a 10 bolt = increased chance of breakage !!!
Old Jul 31, 2011 | 05:26 PM
lol, thanks for the advice
Old Jul 31, 2011 | 09:16 PM
99FormulaM6r's Avatar
If you get rid of wheel hop (#1 10 bolt killer), it might increase the life though!
Old Jul 31, 2011 | 11:08 PM
agree^^^,wheel hop is a destroyer.
Old Aug 1, 2011 | 08:11 AM
BMR Sales2's Avatar
If you have a 10 bolt you are honestly on borrowed time anyways because at some point in time it IS going to break. I know here locally we had quite a few cars run low 10's on them with the good majority of them being automatic cars which are much nicer on the rear ends then the 6 speeds are. Like you guys have already said getting the suspension dialed in and getting rid of the wheel hop will definitely help with the longevity of your 10 bolt and the lower control arm relocation brackets is one of those parts that will really help.
__________________
Glenn ***
Sales Tech
813.986.9302
