Koni adjustable part please help
Old Aug 12, 2011 | 09:32 AM
lil-bit's Avatar
Default Koni adjustable part please help
So we installed the koni adjustables yesterday front and rears. Once we got done we realized there was a washer looking part in the box left over... anybody know where this goes? Its about 3 inches in diameter and about 1/8 inch thick with a small whole in the middle..... I think thats the best way to descibe it.Please let me know if youll have an idea on where that goes... thank you
Old Aug 12, 2011 | 01:07 PM
HAZ-Matt's Avatar
It goes above the front shock in between the shock and the shock mount. You shouldn't have had only one leftover since there is supposed to be one for each front shock.
If you search "koni washer" there are some pictures.
Just for reference, if it is the washer I am thinking about it is 54mm OD, 10.4mm ID.
Old Aug 12, 2011 | 01:12 PM
lil-bit's Avatar
Ya i have 2 left over it looks like this.
its the silver washer.
Old Aug 12, 2011 | 01:17 PM
HAZ-Matt's Avatar
https://ls1tech.com/forums/9982998-post8.html
Here it is... goes right on top of the adjuster hat...
Old Aug 12, 2011 | 01:28 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Yep those are the part that he has left over.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Aug 12, 2011 | 01:39 PM
lil-bit's Avatar
wow. nice find. thank you so much. and yes those are the ones im missing. ok well i guess ill be pulling the assembly apart tonight again. oh well lol. my fault. thanks for the help guys. i really appreciate the time . i want to post pics of the setup when im done. it looks good with all the BMR stuff on there now.
Old Aug 12, 2011 | 03:09 PM
HAZ-Matt's Avatar
The only pitfall I can think of with that is the top nuts are nylon lock nuts right? I don't know how well they will work taking them off and putting them back on.
Old Aug 12, 2011 | 03:14 PM
lil-bit's Avatar
Im not to certain. I would say they are not because the are same ones i used from the stock shock. So with that being said they were taking off when the first set of springs were put on and then i removed them and put them back on again. ....
Old Aug 12, 2011 | 03:22 PM
HAZ-Matt's Avatar
Are you sure about that? I thought they were a different size? I could be misremembering.
Old Aug 12, 2011 | 03:26 PM
lil-bit's Avatar
Ya im pretty sure. The parts seem like they come with the least amount of new bolts and nuts. They make u re use most of your stock stuff
Old Aug 12, 2011 | 04:12 PM
HAZ-Matt's Avatar
It should have come with an upper nut though, not any of the lower bolts. I was trying to remember if it was nylon locking nut or not and I am pretty sure that it is. I didn't think that the Koni even took the same nut as stock...
A lot of people have to cut the OEM nuts anyway so it would be crappy if you were supposed to reuse them.
At any rate, I think the Koni takes an M10x1.5 top nut so if you need another one you can try to find a nyloc in that size, or a regular one and use a lock washer.
Old Aug 12, 2011 | 09:50 PM
lil-bit's Avatar
Ya i believe you are correct. Im gokng to have to look for them tomorrow. I insralled the stock nuts on there though. Seemed like thy went on ok... But i wonder if they fit if they would back of in the future without a lock washer
Old Aug 14, 2011 | 10:06 AM
libertyforall1776's Avatar
Koni SA included front shock nuts ARE nyloc, I just finally finished my fronts this past Friday, and they're 17 mm nuts if I recall correctly...
Old Aug 14, 2011 | 09:06 PM
25thhawk's Avatar
Haz-Matt is right about the size. It is M10x1.50. I double nutted mine just for piece of mind
Old Aug 14, 2011 | 09:08 PM
lil-bit's Avatar
Ya i found them. But i put the stock nuts on. I hope they are ok
Old Aug 15, 2011 | 04:34 PM
HAZ-Matt's Avatar
They take something like a 17mm wrench or socket, but they are M10x1.5 because nuts are listed based on the thread size, not what wrench they take.
Old Aug 15, 2011 | 06:35 PM
lil-bit's Avatar
Ya you guy are right i found them after the fact though lol. Im a tard.
