New hardlines for MWC 9"
What are my options for building new hardlines for my 9" conversion. It's stock width but i'm not wanting to use the factory lines. Will i be able to buy pre flared lengths of hardline in about the right length and bend from there from a local auto parts store? Or do our cars use non-standard fittings and i'll need to flare the lines myself with the right fittings? Anyone do this before (care to share a parts list)? I've read that they are metric fittings/bubble flared, is it that way on both ends?
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
I am not positive, but I do not think the pre-flared fittings used will be at the store. I know that they had none that worked for the front of the car when I went to teh BMR k-member.
I am in the market for a flaring tool myself.
You can rent a line bender in most cases if you don't have one. Though you could also bend them by hand.
You have the old axle out of the car? Take the hard lines off of it and go to an autoparts to store and get pre-flared lines. They should be plenty long enough to cover the modest distance. The longest pre-flared line I ever bought was 10'.
Thanks!
I did my own brake lines with double-flared ends. I don't remember anything about one end being different than the other, but I was merely splicing into the existing hardlines.
Check this thread regarding bubble flares: https://ls1tech.com/forums/tools-fab...lare-tool.html
Also, yes, they are metric lines.
From looking at my new soft lines, they all look to be bubble flare, so pre flared may be an option. I'll probably also by a flaring tool so I can get the lengths just right.
Did a little shopping today, going to use 4 m10x1 to 3/16 adapters and use 3/16 tubing with double flares to re-run the lines.
Anyone know if there is a place to buy tubing with the spring shield on it (abrasion shield)?
