No bumper supports bad for chassis flex?
I have had front and rear bumper supports out of the car for a few months. I love the weight reduction but im wondering if this is not very good for the chassis seeing how the front and rear are no longer tied together. Anyone have any knowledge on this?
I dont see how it would effect the chassis. You got a big old k member and the radiator support running right across the front. I think its more for crash protection. Hit something without it and your going to total your car.
They have to help a little.
You need to install something to help hold the bumper up so it doesnt sag. I used those flat aluminum rods. They are like 4$$ each and easy to cut and bend. Installed them underneath where holes already were. One on high sides and one in front. Then on top where the big push pins were i adjusted them and used some bolts instead of the push pins they have on them. Bumper was way more firm and better fitting.
For the the front in particular I would pull it off and cut some metal out of it then replace it. It's the best (free) happy medium. I cut square sections out of mine and funneled the air from the bumper inlets with metal dryer ducting through the metal support and into the backside of plastic air chamber infront of the condenser. Does it keep the car/engine cooler? Who knows....but it makes me feel good to be sucking more air.
it does NOT mean that the bumper reinforcement is useless in higher speed accidents
as far as removing them: if you get into a wreck w/o them in, be very very nice with the insurance company, they can tell you to go F yourself on repairs because your actions led to your vehicle becoming a 15k repair when it should have been a 5k repair
