LG Coilovers vs Koni/Strano Setup
What would be a better setup for a dd? I don't care about the price between the 2, I just care about the ride. I like the fact that with the LG's I can lower the ride height when i go to car shows. I've heard the konis are more comfortable but i want to hear what everyone else thinks. And yes I have searched and looked this up. I think the LG's are a 600# front and 250# rear springs
unless you're at a different road course once a month and put a new setup on the car for each different track to adjust cross weight and alignment, there's no reason you will raise or lower the car on coilovers beyond the first month other than for setting what ride height you want, and then an alignment. It's probable you won't change it after that (unless you set it too low and have to raise it; in which you'll need to re-align the car). Every time you adjust ride height, you change the alignment settings.
