removing e-brake??
anyhow, just take the hardware out of inside the rotor, remove the cables and the 2 10mm bolts for the handle.
However, if you remove the handle, be sure to ground the wire on the brake handle, that way you can get rid of the pesky drl feature and turn your lights on and off at will
this will set the Brake light on the dash off, but thats what electrical tape is for
. Trending Topics
