Strano Stainless Steel Brake Line Set for LS1 brakes question
Old 09-25-2011, 06:23 PM
Rob94hawk's Avatar
Default Strano Stainless Steel Brake Line Set for LS1 brakes question
Going to put on my LS1 brakes this week however I have an LT1 based car. Are these lines compatible and are they worth it? I have a BMR k-frame as well, any compatibility issues that I need to know about? Thanx
http://www.stranoparts.com/partdetai...=195&ModelID=8
Old 09-26-2011, 09:05 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
I run Russell stainless brake lines on my GTO, they're a terrific, quality package. There are no compatibility issues with using stainless lines with our K-Member. The mounting locations are on the inner fender and the caliper themselves, so our suspension components won't get in the way or impact installation at all.
Be sure to use a good fluid and bleed your brakes when you install the lines. The pedal definitely feels better after you get these in there since the factory rubber lines will actually expand under braking - reducing pedal effectiveness.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-29-2011, 08:19 PM
Rob94hawk's Avatar
Do you have a part # for the brake lines? Is there a difference between the LT1 brake lines and the LS1 brake lines?
Oh and I made the mistake of putting my engine in BEFORE reinstalling the brake on the BMR K-frame. This should be interesting.
Old 09-30-2011, 08:39 AM
BMR Tech2's Avatar
The link you posted from Strano is the part. They're a great thing to buy.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: Strano Stainless Steel Brake Line Set for LS1 brakes question
