Tricks to seperate ball joint?
Old Mar 9, 2004 | 07:29 AM
NHRATA01's Avatar
Default Tricks to seperate ball joint?
I'm in the middle of the shock install I started last night, and of course I can't get the ball joint on the spindle and upper A-arm to seperate. Does anyone have any good methods for doing this? I saw the pickel fork method on JMX's install page, wondering if there was anything else (otherwise I'll have to go out and find a place that sells them).
Old Mar 9, 2004 | 07:48 AM
mitchntx's Avatar
A good solid whack with a hammer on the knuckle, where the shaft of the ball joint goes through, should seperate it.
Old Mar 9, 2004 | 08:52 AM
TaTommyWS6's Avatar
Just get a pickle fork, you are less likely to break anything, and it works great.
Tommy
Old Mar 9, 2004 | 10:03 AM
mitchntx's Avatar
I have yet to not tear a grease boot with a pickle fork.
Trust me ... a solid whack on the beefy part of the knuckle will not not tear anything up. Now don't use a 10lb sledge ... but a 2lb hammer will pop it loose
Old Mar 9, 2004 | 11:26 AM
00NBMCamaro's Avatar
hammer it a few times... you won hurt it..
Old Mar 9, 2004 | 11:51 AM
SS Express's Avatar
I tried a pickle fork first, but It did not work. I then hit it once with a hammer as stated above and it popped right off.
Old Mar 9, 2004 | 01:25 PM
NHRATA01's Avatar
I was whacking it with a rubber mallet last night, but I'll give the hammer a shot, and see if the sharper blow helps it a bit. But I also went over to autozone at lunch and rented their pickel fork for good measure.
Old Mar 9, 2004 | 04:47 PM
Scalpel's Avatar
A rubber hammer absorbs a lot of the impact and makes it less effective. Trust me a whack with a solid hammer (not a nail driving hammer either), a big meaty headed hammer will knock it free.
Old Mar 9, 2004 | 06:09 PM
eswolfgang's Avatar
The hammer method is best for the upper, pickle forks don't seem to fit nicely on the upper ball joint.
Old Mar 9, 2004 | 06:37 PM
tuffluck's Avatar
BFH does it without effort.
Old Mar 9, 2004 | 06:45 PM
glitch77's Avatar
I left my forks and hammers in the toolbox for my front shock install.
https://ls1tech.com/forums/suspension-brakes/116793-f-bod-front-spring-shock-how.html
Old Mar 9, 2004 | 06:48 PM
kevinb's Avatar
I can do mine without seperateing the ball joints.
Old Mar 9, 2004 | 07:53 PM
trackbird's Avatar
Sure.
Old Mar 9, 2004 | 11:32 PM
kevinb's Avatar
Originally Posted by trackbird
Sure.
Seriously. All you have to do is unbolt the upper shock tower bolts and the lower two on the shock, flex the lower a-arm down a little and the upper bolts will pull away from the top, then you can rotate the upper a-arm to the rear and slide the shock assembly out between the lower a-arm and brake line. Easy as cake, don't make it harder than it is. Goes in just as easy.
Old Mar 9, 2004 | 11:39 PM
kevinb's Avatar
Sure.
Old Mar 10, 2004 | 07:22 PM
trackbird's Avatar
Sorry, I misread you post to say "Can I do mine without removing the balljoints". I was saying "sure". Because that is the way I do them. I wasn't doubting you, the post glitch77 listed is how I told him to do it (the same as you).
Old Mar 10, 2004 | 09:16 PM
kevinb's Avatar
Awsome! Just misinterpreted the "sure"
Old Mar 10, 2004 | 09:24 PM
angst911's Avatar
why use a pickle fork when you could use a balljoint seperator (aka pitman puller)
Old Mar 11, 2004 | 07:43 AM
NHRATA01's Avatar
That is what I used...pickel fork was just the nickname for it.
Old Mar 11, 2004 | 04:08 PM
angst911's Avatar
no, pickle fork is the piece w/ two prongs that you wedge in between the two pieces and wedge the two apart. a pitman arm puller is more like a pulley puller type piece. It's got two arms that lock onto the piece w/o the balljoint in it, and a bolt that pushes against the end of the balljoints stud to pull the one piece off the other.
