what pads to get?
I agree, I just installed hawk HPS pads along with my powerslot rotors and they dont dust any more than stock from what I can see. So far I'm very pleased with them. They are a bit noisy compared to stock under very hard braking, but then again the slotted rotors could contribute to that as well.
I'm using the KVR 'Carbon Fibre' Pads in conjunction with their Cross-Drilled Silver Cadnium Plated Rotors and Earl's Stainless Steel Brakelines.
I used the stock pads with the KVR rotors for awhile since I only had 21k miles on them - and they worked fine. I looked at pads and liked the idea of using the KVR pads since I had their rotors but they are pretty pricey. Anyway, I ended up getting a set to finish out my brake package. The feel is great and you actually tell that they brake better than the stock pads. I get a little more brake dust residue, but not bad - I wipe my car down completely any time I drive it anyway. The KVR Part #'s I have are M7618 (fronts) and M7619(rears). Check them out at www.kvrperformance.com . Good luck!
KVR's description of these pads:
Carbon Fibre Brake Pads
KVR Performance delivers a Semi-Metallic Carbon Fibre disc pad which has been proven to demonstrate superior performance.
It's metallurgical formulation exceeds all O.E.M. standards, while still offering a quiet running brake pad with minimal dusting.
Street Performance Requires No Warm Up
Produces Minimal Amount of Black Dust
Excellent Durability and Extended Life
Meets or Exceeds all O.E. Specifications
Kevlar Insulated
Carbon Fibre Weave Rather Than Carbon Dust
Reduction Of Heat Induced Fade
Kevlar Insulated
Or you could go to an actual sponsor and buy them for
$76 front
$67 rear
from multiple sponsors of the board, including Tire Rack and Speed Inc.
$76 front
$67 rear
